Thread: Engine`s gone
Old 09-22-2022, 03:33 PM   #16
Coaster
Coaster's Avatar
Nice build thread - sorry to hear about the recent development.
I've not done any rebuilds but am considering one on my 03 986 S.
Can you give a little more detail about using the extra oil pump housing and pre-filling the oil on the build stand please? Did you fill completely (from the top I assume)? You used the dip stick to measure as you got close to the right amount? You used the drill to load up the block while you were filling? You just swapped out the cover with the drive and the hole-less cover when you were done (messy?)?
2003 S, 6 Speed, PCM, PSM, Bose, Litronics with washers, on its' second LN IMSB, comfort top, UDP, 987 engine mount, 997 RMS, Koni Sport Shocks, H&R springs, Techno brace, comfort blinkers, nin8six windscreen, particlewave light up cubby
Coaster is offline   Reply With Quote
