Old 09-22-2022, 01:24 PM   #12
Infernous428
It used the have an aftermarket exhaust, and I recently had the stock exhaust reinstalled and that's how they did.
The dripping is because it had been pouring outside and I had just driven the car in heavy rain.
I will start with the belt and see what I can find. Honestly the noise doesn't start until about 10 min of driving. How long can I run the car on jdle the car without the belt?
If "you" want to diagnose the cause then you need to start eliminating possibilities.
The easiest way to start doing that is to remove the fan belt (serpentine belt).
If the noise persists after removing the fan belt and running the engine then you will know it is not anything driven by the belt.
If the noise is gone after removing the belt then it is something driven by the belt.
Your not going to get far by just posting video's and asking random people or random mechanics their opinions.
Diagnostics has to be done, that basically boils down to a process of elimination.
I notice a lot of liquid dripping from under the car.
Whats going on there.???
What modifications have you done to the car?
Doesn't look like stock exhaust or it isn't bolted up correctly.
Infernous428 is offline   Reply With Quote
