Old 09-13-2022, 04:12 PM   #16
newBgeek
I just got mine changed thanks to wawa and Jager. The bolt was real easy. It popped out of the hole easy too. I used hose pliers for that but you can probably just pull it out. The trick to disconnecting it from the hose was to turn it 90 degrees so you can grab the vent and hole with your left hand and squeeze the tabs with the right hand. Getting that grip was key because it is so tight in there. I also warmed it up with a heat gun and lubed it with silicon spray to help with removal.
newBgeek is offline   Reply With Quote
