Thread: ABS Light
Old 09-11-2022, 02:40 PM   #10
DrRobin
DrRobin's Avatar
Good news for me, the old sensor came out without removing the hub. It had to be dug out, but the last little bit was loose and came out with a pair of tweezers, so nothing dropped in to the hub.
I then put a piece of cotton wool soaked in bearing grease in to the hole to act as a plug and then cleaned up the hole. Finally removing the cotton wool and inserting the new sensor, a quick check and the fault cleared.
Hopefully I have got away without damaging the wheel bearing (I checked the bearing for play after a test drive and it was ok, no noise and no play) or CV, but I have break down cover and if there is any problems the local garage can get it to replace.
Thanks guys, another repair completed.
Robin
DrRobin is offline   Reply With Quote
