Are you able to operate the door locks via the button in the center console?
I would check the alarm control module under the drivers seat. Especially if the connectors are connected correctly and if there is corrosion in the connectors or in the alarm control module - which is also the bcu.
I don't think that is caused by a fuse.
Also both remotes can be bad. But this in general won't cause the additional problems.
