Right rear ABS sensor reads about 1M Ohm, guess that means it has gone open circuit?
The sensor is on the outside of the hub secured in place by an Allen headed bolt, not sure if it is going to come out, I have seen videos where it is stuck in and needs to be drilled out.
The cable is stamped 00 907 909 966
Robin
