Old 09-02-2022, 06:42 PM   #2
Homeoboxter
Sorry for your trouble. Since two plugs blew at the same time I would think your oil line downstream of the camshafts must be blocked somewhere... Another possibility is that the relief valve is stuck allowing for too high pressure build up and those plugs are the weakest links. That bearing may be repairable in a machine shop but it`s much easier to just buy a used head. Good luck!
