Old 08-15-2022, 04:34 PM   #23
jaykay
jaykay's Avatar
I just completed this modification and tested it. I would highly recommend after testing oil pressure light "out times" and looking at the old piston definately looks like it had been catching/rubbing on the top/leading edge of the piston. A truely awful design.
My research indicated that 50 Nm was the correct torque value.
With the car level alot of oil will drain out so don't walk away and do something else like I did.....So in having to reset the oil level I discovered that one bar above minimum on the dash gauge gives a midlevel reading on the dip stick. This was completely cold and drained as one can be. It looks like the shops I have used in the past have been overfilling the oil.
Edit: It looks like I have used that one bar with some garden driving. Will have to reset again..may try two bars above min. What does this lower level philosophy do yo this ims bearing if anything
986 00S
