Old 08-14-2022, 07:00 PM   #1
MarkAP
MarkAP's Avatar
Coolant refill advice
So I changed the coolant in my ‘04 S because it was green. As I am not sure what was in there (was done before I bought it). I flushed the system twice with a hose, drained it by removing the drain plug on the 3rd rad and “lifting” the hoses on the main rads with a small screwdriver (difficult to remove those hoses) and finally blow the lines out with an air hose. Refilled today with Porsche coolant using an airlift. Issue is the system only took in 5 gallons to fill when the Bentley manual says it should be just under 5.8. Heater was on on drain and filling. I also did the WP and low temp thermostat while in there.
So advice: should I drain and refill (adding another gal of P coolant)? Start over fresh with new P coolant and distilled or just call it good and drive it? FYI Chicago weather but car is garaged Nov to May.
Thanks all
Mark
Guards Red Boxster S, born in Germany May 2004. LN spin on filter, litronics, roll bar mesh, wind deflector. Pioneer AVH-4200 hu, rear shelf box with speakers installed. 36k miles.
MarkAP is offline   Reply With Quote
