Old 08-04-2022, 03:30 AM   #1
Starter986
1998 Boxster Silver/Red
Originally Posted by Most_Wanted View Post
My oil cooler went bad and my mechanic is trying to find the correct parts. The diagram he is referencing shows a "plate" that is sandwiched between the engine and oil cooler. My engine did not have the plate nor do the other 986 engine I've researched on youtube/google images. Can someone with more experience confirm that there is no "plate" to begin with & also on the correct size seals.
2000 Boxster S
Engine 3.2
Seal sizes my parts guy showed me.
28x2.5 mm
35x4 mm
26x3 mm
I don't know why there is 3 different sizes. The oil cooler should only have 2 different sizes correct?
You need a new mechanic.
You have an existing oil "cooler" that went bad. It has a part number on it. Your mechanic should be plugging in that number... sourcing the like part... buying the necessary seals (readily available)... and plugging in the new part. It's not rocket surgery. My wife could do it. You could do it.
I did it.
Matter of fact, if you're local...
Find a better mechanic. If she's hemming and hawwing over a simple remove and replace part like an oil "cooler"...
Hpowever, in spite of my tone... best wishes on a quick and fruitful outcome.
Freaking 4A posting...
1998 Porsche Boxster
