Old 07-29-2022, 10:58 PM   #23
DreamSign
Originally Posted by edc View Post
It sounds like your complaint is the primary ride. I doubt off the shelf coilovers will solve your problem. These are generally aimed at being "uprated" so soft setting isn't necessarily significantly softer than standard. Have a look at the FSD / Special Active. These are similar of softer than stock in the initial primary ride but stiffen up with load. Your other option of course is a custom spec build.
Yes, it seems the special active have been recommended several times. My plan is to first try a smaller wheel with a taller sidewall. I'm going to try a set of indy 500's which supposedly soak up some shocks while retaining a small slip angle when loaded in a turn.
I'm not looking for a huge change, just a bit more comfort over bad sections of road.
DreamSign is offline   Reply With Quote
