Old 07-22-2022, 05:24 AM   #2
Robert986
Let us know if a new crank sensor solves the problem.
If it does not then an issue with the "EVAP" system may be the problem.
Things like a faulty purge valve stuck open can cause hard starting after a refuel and stalling.
Thanks, IŽll report back!
No real problem starting, just intermittent when driving. Did change the purge vave 2y ago so it should be ok.
Robert986 is offline   Reply With Quote
