Thread: PCCM plus
Old 07-20-2022, 07:59 AM   #16
Goldenzrule
Hello JFP, I was trying to get a NAV unit for my 981CS but as you mention it is very expensive, by any chance do you know of a good aftermarket unit that would not look out of place and would be compatible with the OEM system? (which is not a good one BTW)
I would like to upgrade the speakers as well without spending a fortune.. which options are out there?
Unfortunately, this is an area which I don't have ANY experience (or clue) whatsoever, but would like to keep the OEM look, thanks!
I am not a 981 expert, but I believe it does not use a standard double din radio, at least not without some adapters/faceplate trim. I believe the radio has controls under the screen if I am not mistaken. I also believe it uses either the MOST system or some other variation of fiber optic cabling which would throw another wrench into the mix. If you are not up to speed on car audio, I think your best bet is to go to a shop, but I would expect to pay a significant amount, especially if you upgrade speakers as well. At least they can give you a good baseline.
Goldenzrule is offline   Reply With Quote
