Originally Posted by casioqv
Could you share a photo of this? It's hard to visualize exactly what you did, but I am interested in trying it.
Here are the pics. Like I said, it's quite concealed. It runs on top of the sheet metal brace, connecting the two rear most bolt holes on the diagonal braces. It tucks under the exhaust on either side (my exhaust is totally custom though so I can't speak to OEM setups) and then bolts drop down from the top and go through the bar, the sheet metal brace, and diagonal brace) and secured via a nut on the bottom side. The oem bolts here just knock out from the bottom-up.
Sent from my SM-G970U1 using Tapatalk
