Old 07-17-2022, 12:12 PM   #1
A_NeonTurtle
986 clutch pedal stuck
If anyone could help out that’d be great,
Problem : clutch pedal is stuck down and only comes up if I pull it up, car is able to turn on, able shift gears while it’s on, when on it cannot shift gears when clutch is in.
Possible causes:
(I know I messed up) basically launched the car on a steep hill and smelt like burnt clutch the whole way home, after this happened was the first time my clutch pedal got stuck
Weve replaced the slave and master cylinders but to no avail (had some issues bleeding the system so will be doing that again to make sure that isn’t the problem)
The pedal very slightly moves up now after initial bleed
If anyone has an idea of what’s the problem/solution please help
A_NeonTurtle is offline   Reply With Quote
