For what’s it’s worth I have finally got the s axles to easily fit the base hubs. I’m using a different transmission and have never had the stock one so I have no idea on the axle length, I’m not sure if it’s because the S bearings are wider because I had to make a 10mm spacer on my axle. But it turned out to be a simple machining job. I’m hoping the S axles are up to the job. My saving grace is I do not need ABS and I wanted to keep as much material as possible on the hub. But my first Hines I butchered with a 40mm hole saw and they seem to be fine. It may be an easy upgrade as all you need to do is machine the hubs slightly. Put a spacer on the drive shaft, and put a washer under the ABS sensor.
