3.2 - 3 chain engine - P1325 - camshaft adjustment bank 2 (invalid signal)
I have a 2003 (ROW) 3.2 with a 3 chain engine. So camshaft adjustment via oil pressure.
I had a IMS bearing change done by a workshop. Since than the engine shows vibrations in nearly every rpm range.
I've diagnosed it with Piwis and there is a static DME DTC P1325 error. P1325 = camshaft adjustment bank 2 (invalid signal).
I've cleared the code, but it came back after i drove above around approx. 4.000 rpm.
If the code is cleared, the engine seems t run a bit nicer if you only run it at low revs.
Additionally i checked for engine vibrations via Piwis. At low rpms they where at 10% and climbing up with rpms. To me that seems to be a pretty high value.
Camshaft position is on -0.8 and 1.6. So should be OK.
Unfortunately i don't have a detailed documentation on the face lift engines with the oil pressure controlled vane cell adjuster camshafts. But it seems that there are solenoids and connectors that can be checked. Does anybody have a detailed documentation on that?
Also some instructions on that P1325 DTC would be very helpful.
