Old 07-10-2022, 03:21 AM   #12
FoFoJoe
FoFoJoe
FoFoJoe's Avatar
Last update to wrap up this saga for now.
I installed a manual fan switch, some pics below.
https://imgur.com/a/UKIQW4d
I definitely bought mini ATC fuse pin adapters instead of standard ATC, but I bent them and made it work. I secured them to the relay with a ziptie and used a connector. I can take better pics of the relay if anyone is interested.
Other than that, there is a pic of the switch location, ground location and wires coming from the relays.
The results were better than I expected. It's been 95+ here and I can keep the car under 200 easy with the high fans on.
They are most effective at slower speeds but they definitely make a difference at highway speed as well. I can keep the car around 190-195 on the highway at the hottest time of day. In the evening when it cools down I run about 185-188.
I would highly recommend running the manual fan control for anyone in a hotter climate.
I just ran my own ground and interrupted it with a high current switch. The smaller switch is for my USB charging ports that are connected direct to the battery with a fuse so I can run them when the car is off.
2001 Base 2.7l, 5-speed (124k) - LN IMS kit
- TopSpeedAuto exhaust (headers/mid/muffler)
- 997 Carrera III wheels w/ECS spacers 18x8 +15mm/18x10 +18mm, Eibach springs
- FunctionFirst shift knob/short shift kit
- Focal speakers/Alpine amp/Kenwood deck/Pioneer 8" subs
FoFoJoe is offline   Reply With Quote
