Old 07-08-2022, 11:03 AM   #4
DreamSign
Originally Posted by casioqv View Post
Wow, 34k miles, looks brand new! Any info about learning how to do polishing like this?
It is actually surprisingly easy. I watched a bunch of youtube videos and what I found was:
1. Wash the car with an appropriate soap to strip all the wax. I used chemical guys product "clean slate"
2. Clay bar the paint to remove particles and impurities, this is also very easy, you just spray on a lubricant (like soapy water) and slide a bit of clay around all the paint, you will feel it go from gritty to smooth quickly. I used chemical guys "OG" clay, but any pro clay will do fine.
3. I washed again after this.
4. Buy a REAL dual action polisher. I bought this one $109: https://www.amazon.com/gp/product/B07P2BWRXH/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1 and buy separately the pads you will use (use good pads, the cheap ones end up costing more)
I used these two polishes which are both on the lighter cut side, deep scratches would benefit from more aggressive compounds:
first polish:
https://www.amazon.com/dp/B00DKYBK0C?psc=1&ref=ppx_yo2ov_dt_b_product_detail s
final polish:
https://www.amazon.com/gp/product/B00FJG0LU4/ref=ppx_yo_dt_b_search_asin_title?ie=UTF8&psc=1
Then I used chemical guys butter wet wax.
https://www.chemicalguys.com/butter-wet-wax/butter-wet-wax.html?gtmListValue=Internal%20Search
Of course there are many many products that will give you the same result and 'experts' love to opine about why their product/method is superior, but the pictures show an 'acceptable' outcome
Here it after a 2nd finer finishing polish and wax:
DreamSign is offline   Reply With Quote
