Originally Posted by Adam
Sammy, the clutch should be bled just like the brakes. I plan on doing mine this weekend and I will try to get a picture or two and a quick writeup for you on the procedure. I will be using a power bleeder for this job. The clutch works off the same master cylinder and resevior as the brakes. The bleeder valve for the clutch is actually attached to the slave cylinder on the left side of the tranny. Just put a rubber hose on it like the brakes and bleed away.
Thanks for the information, but my question is how do you physically get your hand and a wrench to the bleeder valve on the transmission to bleed the clutch? I found the bleeder valve but in working from underneath the driver rear of the vehicle I couldn't get my hands and wrench on the valve.
