Old 07-06-2022, 04:26 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
I bought a cheap one similar to that a few years ago. It functioned and I used it more than I expected. Make sure that you have enough cfm of air output from your compressor to run it. Expect the fittings to leak after a few uses and have a towel ready in the trunk.
If you are using it once and not likely to do it again, check if your local parts store loans a good one. I'll probably be putting mine in the trash soon and buying a UView.
