Old 11-07-2006, 08:53 AM   #16
z12358
MNBoxster:
"You could install adjustable stands or wood blocks under the bottom of the struts at ride height (raise the axle higher, install blocks, and lower) to keep everything in it's nominal state. But, the only benefit is that you reduce the potential for flat-spotting the tires which you have already done by over-inflating them. Won't hurt to do it, but won't help either and it's a lot more work (both at hybernation and reawakening times), + it makes it very difficult to move the car in the event this is needed. Hope this helps..."
So he does eliminate the potential for flat-spotting without any negative effects, apart from the hassle involved. I didn't know those points existed. As you say, it's a good day whenever you learn something.
Thx.
Z.
'06 Boxster S, 6sp, triple-black
http://i153.photobucket.com/albums/s...05_IMGcrop.jpg
z12358 is offline   Reply With Quote
