Old 07-05-2022, 09:26 AM   #10
LincolnPeters
Perhaps the worst example
LincolnPeters's Avatar
Finished this yesterday after three days of fussing with it off and on. Reading through the comments—everyone here is spot on.
My 2 cents, Blue and Rob175 nailed it in the comments. Starting from scratch, I’d totally spend $750 for an indie to handle this…but having done it once I think I could do it again in a couple-3 or four hours hours over two days.
Highlighting from below: No problem for me reusing the hose clamps.
You absolutely want the cable actuated hose clamp tool, and I’d get one shaped like a needle-nose that works at right-angle when I do this again…which I’ll have to do because—-
I couldn’t get the coolant level sensor back in after replacing the tank. There must be a molding blemish blocking the slot it slides in it that I should have checked before remounting the tank. Using it without the coolant level sensor for now…
My takeaway: This was all kinds of frustrating and F’d off. Glad I did it at home? Yeah, but it was dicey at points and scary that I might not get everything back together.
Peace and good luck.
‘97 986 with ‘00 2.7, 5M
“Were most of your stars out?”
LincolnPeters is offline   Reply With Quote
