Old 07-04-2022, 05:34 PM   #1
78F350
Motorist & Coffee Drinker
78F350's Avatar
You can get easy access to the fuel sending unit and hoses by removing the battery and battery tray. If it's leaking from the top, that is the most likely area for a problem. No need to drop the tank unless all of that looks good.
This Tech Article at Pelican has most of the procedure outlined with pics.
https://www.pelicanparts.com/techarticles/Boxster_Tech/22-FUEL-Fuel_Pump/22-FUEL-Fuel_Pump.htm
