Old 07-04-2022, 05:21 AM   #120
Starter986
1998 Boxster Silver/Red
Originally Posted by Carlton Bale View Post
Here’s a video showing how to repair both blend doors using plastic plugs from seller DSP on eBay. It turns out many VWs from the same era have the same problem. When researching that VW problem, I noticed that the blend doors are almost identical, and the plastic plugs work actoss both.
This method goes through the center dash vent behind the radio, similar to other repair methods.
https://youtu.be/ZiFFllCzlxc
The plugs are overkill. $40+ for something you're not going to see... and $00.25 worth of tape achieves the same end result.
1998 Porsche Boxster
