Make sure your oil is not overfilled as well. While replacing the AOS did solve this for me, I remember reading that due to the flat engine overfilling can put you in a situation were the oil sits against the rings and seeps through. The dash oil level indicator has a full line that is below the final bar. Make sure you are not above that fill line.
Something to check that is an easy fix.
