Thread: clutch issue
Old 06-24-2022, 01:59 PM   #2
JFP in PA
Originally Posted by casioqv View Post
If the slave cylinder is leaking you will have fluid running down the left/drivers side of the transaxle.... most likely it's the master cylinder *plus* the return spring that are both bad.
Bad slave or master cylinders do not necessarily leak externally, either can have internal leaks that allow the pedal to move.
