Old 06-18-2022, 05:02 PM   #30
KevinH1990
KevinH1990's Avatar
What? Dont understand this (and never use something made to be used in a house in a car. lol).
Definitely not one of my better ideas.
If the CD-player bracket is attached to the bulkhead like the Hase amp, it looks like the OEM technology uses a piece of rubber with a hole in the middle to receive a fastener. The rubber piece has a groove in the middle of its outside edge. The two outer lips are larger than the opening in the sheet metal and the rubber piece is wedged into place.
I may have trouble hunting down the OEM part and will need to develop another option. The bottom of the CD-Player bracket has a large tab that inserts into a slot in the frunk floor. You can see it at the bottom of this photo:
That holds it fairly securely especially since the amp is small and mounted low. I may not need the upper fasteners.
