Old 06-11-2022, 05:16 PM   #3
bg305
01 Seal Gray 986 S
bg305's Avatar
Originally Posted by elav View Post
There are a lot of micro switches. Which one did you replace? It is probably the latch as elgyqc indicated. Mine wasn’t the typical cracked solder joints but the plastic arm taking a set and not engaging the micro switch there enough. Cheap enough part to simply replace.
I replaced the one on the outside door handle. Definitely going to have to dig deeper.
bg305 is offline   Reply With Quote
