I installed a fixed stabilizer bar with the wheels off the ground, and I would recommend an alignment. If you manage to install the bar and everything stays lined up (aka you are easily able to reinstall the bolts) then you may be able to skip an alignment. When I installed mine I couldn't get one of the bolts back in even though nothing had visible shifted during the install. I had to have the place that did the alignment install that one bolt.
