Yes to all the above.
Instead of dropping $100, I bought a 3/4" square x24" long bar of extruded aluminum, knocked out the OEM bolts, and drilled the bar to fit. I positioned mine above the diagonal braces so that it's completely out of sight.
If you only drive in a straight line you will never feel a difference. If you push it around corners though (even spirited daily drives) the difference is definitely there. It's hard to describe except to say that the rear end "feels more planted" and with less flex. For $30 it was a great mod.
Sent from my SM-G970U1 using Tapatalk
