Old 05-30-2022, 12:59 PM   #47
KevinH1990
KevinH1990's Avatar
I removed the latch to check the microswitch. There are three electrical connectors that attach to:
1. The light
2. The microswitch
3. The motion detector
Connector #3 had worked loose. I reattached it and that resolved the problem. The car no longer beeps twice when I lock the doors. I'm wondering how it worked loose.
I must have had two problems that started around the same time - the passenger door microswitch and the loose connector.
I may have replaced the ignition switch unnecessarily. I will keep the one I removed as a spare.
Thanks for the suggestions.
KevinH1990 is offline   Reply With Quote
