Those look great!!! Also gets more immediate attention! My 3rd Brake light arrangement had a broken solder joint inside it. So I took a 10" LED from one I was going to use on my VW Bus, gutted it and put it's guts into the Porsche housing. I used a Dremel to remove the plastic bulb housings, glue gunned the LED Strip into the old backing plate, soldered to the existing terminals. Works Great. I like LEDs so much better than conventional bulbs.
