Old 05-27-2022, 02:26 PM   #14
JP Summers
JP Summers's Avatar
Update:
Windows are working as advertised. Courtesy Drop & Raise from Key, drop to open doors or top and switches work.
Problems:
Left A-Pillar had the Gray/Red Wire corroded from both terminal Blocks. Rewired, Resealed.
Right Motor was seized. Removed, Lubricated, applied power, works.
Both Regulators are fine. Lubricated and working properly.
Locks are no longer a "big" Issue. They mostly work. Locks only w/ Key in Door, also sets Alarm & Locks Fuel Door. Unlocks and disable Alarm w/ Fob.
Fix:
Cheap Amazon $30 Latches for VW, Audi, Seat, etc. Part# 3B1837016A - RIGHT SIDE, Part# 3B1837015A - LEFT SIDE THIS IS FOR '97 MODEL YEAR ONLY!!! as it has a different latch set than any other year.
JP Summers is offline   Reply With Quote
