Old 05-27-2022, 10:35 AM   #30
Homeoboxter
Just in case you or someone else following the thread have the common problem with the bolts that hold the top latch in place, here's a link about replacing the rivet nuts that it bolts into:
https://986forum.com/forums/attachments/performance-technical-chat/13799d1298241033-visor-attachment-issue-nutsert-install-upload.pdf
Thanks for this, it`s good to see that I came up with almost the same solution a few weeks ago without seeing this DYI. I bought the same insert at an ACE hardware but glued it in with epoxy instead of drilling an extra hole. It worked.
