Old 05-26-2022, 07:38 AM   #165
truegearhead
truegearhead's Avatar
Originally Posted by ike84 View Post
Thanks for all that info! What did you do with the OEM tank and pump setup? Did you leave them both in place and add a second stage pump to up the pressure? Or did you scrap it all and go with a totally new system?
Sent from my SM-G970U1 using Tapatalk
I used the OEM pump and tank (I added a second inline pump to get the fuel capacity up). I basically followed what the 996TT guys did. If you want to get fancy there are 996TT E85 conversion kits out there, just make sure you select one with a return line or no return line depending on your setup.
1997 Boxster 4.2L Audi V8 Bi-Turbo
2003 911 C2
NASA HPDE Instructor
truegearhead is offline   Reply With Quote
