			I think you will run faster on straightaways with a staggered setup, 225 or 245 (at most up front)
The only other thing you can do to help is the intake, which sounds like you're pretty much stuck with. I would find any way possible within your rules to make modifications here. Even if not adding parts, "substituting" the existing layout with larger diameter components. I really think 82mm is a magic number here, from TB to MAF housing to airbox. This will need a 996 tune to with but it will help (I'm so sure that I'll bet $ on it)
Sent from my SM-G970U1 using Tapatalk
