Thread: Thump and knock
Old 05-12-2022, 01:51 PM   #2
DWBOX2000
On the early (pre-2000) cars, these codes indicate an overly lean condition, usually an intake air leak or low fuel supply.
Thanks, should I start with spraying some starting fluid around idling cold motor and if no increase in revs, go to fuel filter? Would dirty MAF be a possible problem. When he 1st had this issue, the air filter was really dirty. We replaced but didn’t fix problem. Maybe that would do the opposite of running lean.
Thank you.
DWBOX2000 is offline   Reply With Quote
