Btw, I would like to make a suggestion about the top removal process. Removing the B pillar trims in the beginning makes it WAY easier to access the 3 bolts and only takes a minute per side. Also, disconnect the transmission arms from the top at the ball socket joint only - do not alter their position on the slider. It's not the hardest thing to line it back up if you did this but it will cost you an extra 15 min or so that's unnecessary.
Sent from my SM-G970U1 using Tapatalk
