Old 05-11-2022, 10:00 PM   #14
ike84
Originally Posted by Outkasted View Post
I like the two added buttons. I assume that is for your push start.
Thanks man! Yes it is. I tried posting a video of it but I was unsuccessful.
I don't know why but I find the buttons to be super satisfying to use. One bend per to the car, the other starts it.
Maybe tomorrow night I can finish up the center panel - 2 oil pressure gauges, a master kill switch, and two small lever switches for the OBC.
Here's another pic of the dash sheet I fixed the lights issue.
Fwiw what i said in a different thread was incorrect. There are now small (t5) LEDs and twist lock bases to fit them, which fit perfectly to replace all the small bulbs in the cluster. You can get them on Amazon if anyone is inclined to do so. No more needing to solder LEDs across the contract points, just plug and play.
Lastly, I got the top back on. Not super happy with the new window but it's a hell of a lot better than the old one and if it doesn't leak then it's good enough!
Sent from my SM-G970U1 using Tapatalk
