Old 05-11-2022, 09:35 AM   #1
ike84
Tommy, for whatever reason, the plug I'm holding actually has another connection point at the bottom of that trim piece (I suppose so that it can be removed with the trim piece?) If you remove that trim piece you may find the same thing there for your connector. It's a simple removal - 8mm bronze nut holds tension on the inside of the top rail of the trim, and then it just pops out (2 plastic tabs along the side and bottom hold it in place). Btw, you don't have to completely remove the nut, just loosen it.
Sent from my SM-G970U1 using Tapatalk
