Old 05-09-2022, 04:23 PM   #11
ike84
distributor?
Simple tests...does the dash light up when you put the key in the on position?
The dash has been off this whole time so not sure
The current distributor is a box of solid state fuses under the passenger dash it gets a direct feed from the battery hot terminal.
The Immob fuse is fine. Board doesn't show any scorch.
I've gotta read about immob errors. I think the single horn thing may be part of it.
I also forgot to mention that I resoldered the roof microswitxh contacts. I know the. motion sensor ties back into ecu too.
Lots of homework to do
Sent from my SM-G970U1 using Tapatalk
