Old 05-09-2022, 03:01 PM   #13
ike84
Start at that sharpe "V" closest to the door. then work slowly to the right. That will lift and roll metal towards the door which will unlock that mess in the lower right and move some metal away from the rear window.
Think of how the pleats in an accordion open and close. As the edges of the pleat move out and up the center ridge opens and drops.
With a "V" as sharpe as the one pointing at the door you want to start as close to the "V" as possible with your pull tab and still move metal.
The sharper the "V" or ridge the more tension or pressure locked up in that area.
Your only going to be able to rough it out because you can't get to the back side with anything.
But you may be able to move enough metal to improve the gap at the window and the door if the door gap was affected.
Then you can level it with Bondo as you said.
So it is more important to get the highs down (gently) then it is to get the lows up.
Thanks again blue. I got sidetracked by the ignition issue and haven't started it yet but I will post pics on progress when able to do so..
Btw, starter, sorry for hijacking your thread
Sent from my SM-G970U1 using Tapatalk
