Old 05-09-2022, 12:22 PM   #1
ike84
I have angered the gods...
In my quest for a keyless ignition, I have buggered something up.
Essentially, the car is acting as if there is no key in the ignition. But there is...and the ring and receiver are connected as they should be.
I checked my fuses and everything is intact. I pulled the starter relay and bypassed the terminals and the engine will indeed crank with my push buttons but will not turn over, telling me that the fuel pp relay also isn't getting activated. This tells me that the ecu is acting like it's not sensing the key.
I'm sure there's something im missing here... Another fuse, relay, connection point, grounding wire, something that blew or got knocked loose while under the dash.
Any help is greatly appreciated.
Sent from my SM-G970U1 using Tapatalk
