Husker is spot on.
This is not a panel you want to experiment with, try to learn body work on, or go as cheap as possible on.
A novice would make a mess of the repair, do real damage to the metal and end up with something that looked far worse then it is now.
Pulling is not as simple as it sounds. You have to have knowledge and experience. Done correctly it looks very simple, done wrong and you will make a real mess of things.
If you want it done right take it to a Qualified professional that knows his trade.
