Old 05-05-2022, 03:46 PM   #14
blue62
I'm going with single walled. I put my hand between the pained rextrior and behine it... and it's one sheet. No double... unless the "double is, like, 1/16" thick.
The CL quote is $380. Doesn't meet the acid test. I stopped by a body shop, local, and got a solid quote. $1K out the door. He described the glue/weld/stick process... paint the "injured area... would look new. Would take around 2-3 days.
That $1K would have been my deductible... so I believe I came out ahead on this one.
I really appreciate the input, fellas.
After the repair I'm adding comprehensive.
By glue/weld/stick process your talking about pulling as I mentioned.
80-85% of that dent can be pulled out in just a few minutes.
It's the final 10-15% of the work that takes the knowledge and skill.
Post some pictures of it repaired if you get the chance.
