Old 05-03-2022, 12:14 PM   #10
Smallblock454
First from what I see in your picture all of the metal damage can be repaired including highlight lines and "hard" edges. If someones says it can't be repaired find another PDR tech.
What I cannot tell from the picture is paint condition.
I can't tell if the whiteish color is paint from the car that hit you or if it is primer under your paint.
Have a PDR tech. look it over.
A good PDR tech. will tell you how far he can bring it back including paint condition.
If he can't tell you that find one that can.
I don't agree on that, because there is a big risk that you loose the metal integrity, because the metal was overstretched at the "cuts". That can cause a wobbling surface. It might be possible to get a good result from 10 feet away, but you'll never get a perfect result and perfect metal integrity / strength. Also the paint is damaged for shure. So at least a sport repair paint job will be needed. Because the color is silver, that's not easy to do too.
So to me this doesn't look iike a PDR / spot repair job.
But show it to some PDR techs.
