Old 04-30-2022, 11:12 PM   #1
ike84
I got the switches mounted tonight, hopefully will get the relays wired tomorrow. Also tonight I made my switches for the OBC - spdt momentary toggle switches. If the terminals for the dash side fit I will post the part numbers. That's the last part that needed to be completed before that dash his back together so hopefully I will have her running again in the next few days.
On a side note, I have got to get better at soldering. I have noticed with my relays and these toggle switches that the posts heat up enough to liquify the plastic housing just enough to allow a faction of a mm movement. It's a small amount, but enough to cause continuity issues when working with precision electronics. I don't know if it's my technique, my solder melt point is too high for this type of work(97sn3cu), or if Chinese plastic is just that ****************ty. Any suggestions?
Sent from my SM-G970U1 using Tapatalk
