Old 04-29-2022, 06:46 AM   #1
BrantyB
I would suggest GT3 lower front control arms, they will HELP with tire wear, not cure it. They are not cheap but offer the biggest bang for your buck. And I would not do lowering springs, they are not necessary. Then drive the car...alot. Then see if it needs anything else to fit you. Probably sway bars and wider wheels down the road. Its real easy to dump money into an autocross car that doesn't pay off.
Also, your tires are not good for autocross, but they will teach you how to control the car with their limited grip. Again, you'll learn more and when you do eventually get ax tires you'll already have a good base.
Resist the temptation for immediate satisfaction and think of it as a learning timeline that will eventually reward you.
2022 PCA Zone 7 Autocross Chair
2001 Boxster 986 (base) #414
-PCA GGR: Class Champion AX12 '18, '19, '20; CC06 '21; CC05 '22; PAX 5th '19, 3rd '20, '21, & '22
-PCA Zone 7: Class Champion P14 '18, '19; P02 '20; P-03 '22; PAX Champion '20 & '21
BrantyB is offline   Reply With Quote
