Old 04-26-2022, 10:35 PM   #7
Smallblock454
Seems like the mechanism is put together with Torx screws. I would open that thing and inspect everything.
Your description sounds like the is a bad solder connection or a bad or corroded contact. So i would inspect the wiring, the contacts and the solder points. Of course it can also be a bad micro switch.
If you have Piwis or Durametric you can check the M535 for DTCs so you know exactly what causes the double beep of the alarm horn.
Smallblock454 is online now   Reply With Quote
